engineguy
in reply to: andy.concept303
@andy.concept303
Hmmm, only thing I can think of that is simple to do would be to assign a different Offset for the same tool under your "Post Processor" tab in each different Operation, that way Fusion will see them as different tools and output the code accordingly, I don`t know how many offsets you have in the control but it is a simple, easy workaround that doesn`t involve editing your PP.
I have attached a small Lathe Program with three operations and the code as generated here using the latest version of the HAAS Turning PP, Face, Rough and Finish all with the same tool but different offsets so you would just use the appropriate offset for fine tuning your sizes, seems to be OK here but it may not be what you are looking for !
