Rhino_3D
223 Views, 3 Replies
How to pick heights as "Selection"?
When I try to pick one of the heights as a "Selection", only the top
parts, directly on the surface of a body can be selected:
This does not work for any geometry below:
And when it's clicked, the "Selection" gets replaced with the file name:
In this example, it was possible to select the edge through the hole at the bottom, so I
assume that the overlayed height layers from Fusion are selected here.
So, how would I do this when I don't have a hole in the bottom?
Yes, one could create some additional points in a sketch or wherever,
but how can I pick any geometries through these overlays?
