- Mute
- Permalink
- Report
How to pick heights as "Selection"?
When I try to pick one of the heights as a "Selection", only the top
parts, directly on the surface of a body can be selected:
This does not work for any geometry below:
And when it's clicked, the "Selection" gets replaced with the file name:
In this example, it was possible to select the edge through the hole at the bottom, so I
assume that the overlayed height layers from Fusion are selected here.
So, how would I do this when I don't have a hole in the bottom?
Yes, one could create some additional points in a sketch or wherever,
but how can I pick any geometries through these overlays?
- Mute
- Permalink
- Report
You have a sketch visible and are inadvertently selecting the sketch rather than the geometry you want,
Turn the sketch visibility off and you should be good to go.
I find this quite annoying but have gotten used to it.
- Mute
- Permalink
- Report
Or you can "long press" with the left mouse button and select from the list that appears
Seth Madore
- Mute
- Permalink
- Report
Thanks to both of you!
Turning off the sketch also has the advantage of less flickering, one of the
main reasons I avoid Fusion whenever I can ![]()
Thanks!
Fusion
