- Mute
- Permalink
- Report
Good morning,
Running a probing cycle to pick up a bore for 2nd op machining but getting an alarm on the G65P9810 retract line.. I have worked around this a couple of times in the past by changing the G65 P9810 to G01 but would like to figure out why I am getting this alarm. Any ideas why?
Definitely not a Fusion error but thought I would ask here
Thanks in advance!
Posted code:
G00 G90 G54 X1.540 Y-1.250
G43 Z1.0 H31
G65 P8932
G65 P9810 Z-0.25 F150.
G65 P9814 D1.65 S2
G65 P9810 Z.5 F150. *Alarms out on this line, 1086 (PATH OBSTRUCTED)
G65 P9833
G0G53Z0
- Mute
- Permalink
- Report
Hmm, this sounds like an odd one.
You have a protected position move to start (P9810) so there is not an issue there.
Does it do it every time?
Things I would try:
1) Put an M0 before the problem P9810 line and look if the probe is triggered or not before the move starts.
2) When you get the alarm, is the probe triggered or not? (Green light is not triggered, Red light is triggered)
3) You could be having a false trigger because of the speed the P9810 is done at, change this to F10 just as a check.
Richard Stubley
Product Manager - Fusion Mechanical Design
- Mute
- Permalink
- Report
Probe wasn't triggered before move, tried a G4 before that line and even slowed the feed.. Even though I wasn't seeing a battery alarm, I put in fresh ones and it seems to be working now..
Thanks for the help.
Fusion
