09-13-2021
06:39 PM
- Mute
- Permalink
- Report
09-13-2021
06:39 PM
Start here https://help.autodesk.com/view/fusion360/ENU/courses/
Also, look up NYCCNC on youtube he has done a few vids on the tormach.
With your model, it is can the tool fit in most areas if not, usually you do another toolpath or reduces the stepover and or duplicate the previse toolpath using a smaller tool with the rest machining on.
The item is quite small so you will need to get something like a tapered cutter with a tinny tip like this https://www.toolstoday.com/v-11609-46280.html to finish the toolpath.
Example attached.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Fusion
