- Mute
- Permalink
- Report
Hi, apologies for delay, things have been busy at work and I've only just managed to take a look at this again.
I simplified things by creating a simple 20mm square to carve out of the top of some scrap using the same face-->3DAdaptiveClear-->2D Profile workflow and it shows the same issue (good). The file is attached,
I also created the same 20mm square using Aspire VCarve and, running the GCode created by that, the square is perfectly central to the workpiece as expected. This rules out any mechanical issues in my opinion.
My thoughts are that this might be some funky tool offset thing or other part of the MACH4 post-processor script that might be the culprit. I will try to delete and reinstall also perhaps go with the MACH3 post as this seems more widely used/supported?
The picture attached shows the results of the test. The two test pieces on the left are using Fusion, the one on the right the VCarve Gcode.
Patrick
Fusion
