43687269737469616e
296 Views, 2 Replies
Challenge exercices 2: Introduction to 3D Modeling for Manufacturing > Parametric modeling in Fusion 360: Sketching
Hello fellow kids,
The challenge exercice mentioned at the tittle, ask me to do a loft on a file that is a semisphere and a 4 sided prism. I tried to make 2 construct planes. One for de base of the cube an another for the tip of the semisphere. I did 2 sketches, one rectangle at the base and a point on the tip. Then I applied a loft, but the edges are sharp, how I round It? I tried to put a fillet, but is not working as I expect, and I feel that I'm missing something.
Thank you in advance ^^
@43687269737469616e
Have you tried putting the fillet on the corners of the base rectangle ??
Yes, finally I got it, I was to obsessed only doing the loft, and I was putting the fillet after the loft and not before. Finally few minutes before going to sleep, I tried putting the fillet first a the base.
Thanks!
