engineguy
in reply to: k.petersenRJ3MZ
@k.petersenRJ3MZ
Apologies for the delay, had to go out for a while.
First thing, the G20 and G21 are as you rightly say not in the list of G Codes, (I missed that :disappointed_face: ) I have modified a Fanuc Post Processor so that it does not output any G20 or G21 so try the attached .cps file, just save it to your computer and copy it to your Clipboard,  then open your Posting Dialog, select Setup and from the list that wil appear select "Open Folder" and then just "Paste" the new .cps file into that folder, then you need to close the Dialog by clicking "Cancel", now when you re-open the Posting Dialog you will be able to select the new modified Fanuc Post Processor.
which I named Fanuc(3)-SYNTEC so it might be easier for you to find :slightly_smiling_face: :slightly_smiling_face:
Second one is that you probably have the "Preload Tool" set to "Yes" (This is the default) so change it to "No" as in the image below and the preload tool will not be output.
