engineguy
in reply to: k.petersenRJ3MZ
@k.petersenRJ3MZ
OK, first part, Inch or MM, in your "Manufacture" area go to the top left of your screen and look for the  Units as in the image below, whatever you set there MM or Inch will be output in the code, set to Inch and you will have a G20, set to MM and you will have G21. The Post Processor will output whatever is set here automatically :slightly_smiling_face:
If you are always going to be working in Inches then you cn make Inches the "Default" so you will not have to make any changes again.
For seting the WCS point (Corner or Middle) that is done in the Setup, see image below, with the "Box Point" selected as in the image you can click on any of the points shown and that will move the WCS to that location. Then use the same loocation on the Stock on your CNC Machine, they have to be the same for it to work correctly :slightly_smiling_face:
 Hope that helps :slightly_smiling_face:
