08-04-2021
11:00 AM
- Mute
- Permalink
- Report
08-04-2021
11:00 AM
Well, there you have it, choice is yours, either go and get the Vectric software or stay with Fusion and start as Seth @seth.madore rightly says either the Fanuc or Mach3 Post Processors.
I had a look through your Manual and the G codes, look fine (ISO) and as already mentioned earlier you should do a small, simple program and generate some G Code and try loading it into your CNC Machine Control and see if it will work.
You have the full Manual so go through the setting up of your machine carefully and I think either of the already mentioned options will work for you ![]()
Fusion
