08-02-2021
01:09 PM
- Mute
- Permalink
- Report
08-02-2021
01:09 PM
Hello @Anonymous,
I don't know if you have already modified your post, but adding the rewind/reconfigure logic to a post has become much simpler now. You can copy the following code from the RS-274 Multi-axis post into your post.
// Start of onRewindMachine logic
var performRewinds = true; // <<< CHANGE TO 'true'
// End of onRewindMachine logic
And add the following commands to onOpen prior to calling setMachineConfiguration (also copied from the RS-274 Multi-axis post).
// retract/reconfigure
safeRetractDistance = getProperty("safeRetractDistance") != undefined ? getProperty("safeRetractDistance") :
(typeof safeRetractDistance == "number" ? safeRetractDistance : 0);
if (machineConfiguration.performRewinds() || (typeof performRewinds == "undefined" ? false : performRewinds)) {
machineConfiguration.enableMachineRewinds(); // enables the rewind/reconfigure logic
if (typeof stockExpansion != "undefined") {
machineConfiguration.setRewindStockExpansion(stockExpansion);
if (!receivedMachineConfiguration) {
setMachineConfiguration(machineConfiguration);
You may have to make minor modifications to the code, but it should be close and give you a starting point that we can work from.
Bob Schultz
Sr. Post Processor Developer
Fusion
