SGoldthwaite
405 Views, 4 Replies
3D Contour doesn't get flat bottoms
I am trying out a 3D contour on an STL model.  I noticed the path generated doesn't get the flat surfaces of my model. Why is that.  Is there a setting I need to enable?  See screenshots.
Tags (1)
Labels (1)
  • CAM
seth.madore
in reply to: SGoldthwaite
Hmm, it's possible that it's being limited by the Heights tab, but it's hard to tell with the limited info you have provided. Can you share the file?
Seth Madore
SGoldthwaite
in reply to: seth.madore
Bottom height is model bottom.  I attached the file
Steinwerks
3D Contour is much more a "steep" finishing toolpath than a flat finishing one and wouldn't do a good job anyway. Usually you need a secondary toolpath like Scallop, Parallel or Horizontal for finishing flats well.
The Steep and Shallow toolpath is similar to this blending of toolpaths although more refined.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
SGoldthwaite
in reply to: Steinwerks
Thanks. I'll use a horizontal toolpath for the flat areas.
