469 Views, 6 Replies
2d adaptive open pocket problem since last 360 update.
Hi All,
Hopefully someone can help me out here,
I had been using 2d adaptive to clear multiple recessed areas in the attached design simply by selecting the faces which worked perfectly. Since updating, I am getting an error "Unsupported Geometry for 2d open pocket detection" and I can't find any other way to achieve the clearing operation using either 2d or 3d as both now need require contours to be set which leaves unwanted stock where the tool would stray outside the set area.
I'm using a 1/4" mill.
(I'm reporting this using an export from an earlier version of 360 to get around the problem
(2.0.10356) but anyone with Fusion 360 CAM 2.0.10440 should be able to reproduce the issue.)
Looking forward to hearing back.
Labels (1)
