Z-K-O
in reply to: JOKM_Creative
I figured out how to get it to work, based on the following very bare thread:
https://forums.autodesk.com/t5/fusion-360-manufacture/insert-tabs-and-cut-them-away-in-next-op/td-p/...
Posting it here to save others all the screwing around.
Once you've made your 2D Contour with tabs, make a 3D Contour with:
- Rest Machining on, and a very high Ignore Cusps value. I used about 0.04".
- No lead in/out.
- A short ramp or a plunge entry.
This should save you the headache getting to the point of functional,  where you can make your own tweaks from there.
