in reply to: daniel_lyall
Hello again,
well, you will probably agree with me that this example is not very practical. with the adaptive and the parallel the tooth is not machined all the way and it takes 10h to make one single tooth (40 teeth = 400h) lets say it could be reduced in half by optimizing the toolpath and sacrificing some roughness  and it will still take too long. That strategy would work for short gears and still will not be optimal.
I think the best way to figure it out is if the Fusion Support team does some updates. On a conventional machine this could be done very easy, on a CNC it should be even simplified. I saw these videos and I was hoping on a similar result.
https://www.youtube.com/watch?v=mz1-vW-CaPw&ab_channel=BudikaryaTeknik
- https://www.youtube.com/watch?v=ROCt9BHKcQU&t=10s&ab_channel=TmSkrbl
 I don't think they have been done on Fusion
Thanks for the help, I really appreciate it :slightly_smiling_face:
