Disclaimer: Ive only been working with Fusion 360 for about a month. If I understood you correctly, you are wondering about how to set dimensions? You can set dimensions when in Design mode > Create. Whenever you create something, the dimension is something you determine and adjust. Manufacture mode operates as the CAM software. You can set just about any dimension you want once you understand what is that you want to do. Download the program and start playing. That is the only way you will learn, and It will become more clear/fun.
