a.laasW8M6T
in reply to: afalzate
I assume your using a 2d contour?
If you turn on stock contours in the geometry tab and pick a contour that matches the extent of the part you want to avoid, fusion will add the appropriate extension to the paths to avoid a collision,
if you share the file I can show an example
