07-03-2021
08:24 AM
- Mute
- Permalink
- Report
07-03-2021
08:24 AM
I am using a 3 axis mill and a key seat cutter with a small neck.
I am undercutting and I wish there was a way to specify an exit path when finished. As you could imagine, when the current strategy is done from the pictures, it moves out vertically and could damage the tool or part with the final retract. One solution I found before was adding a large Lead in/Out horizontal radius but that consumes a lot of unnecessary time cutting air between the roughing cuts. My final solution was just manually adding a linear move in the G Code by hand after posting, but I wish there was a way to fix this in the source file.
Fusion
