FrodoLoggins
457 Views, 3 Replies
Toolpaths stuck at 0%
Used to generate, won't anymore. Stuck a 0%. Changing to a different ballnose generates in 2 seconds.
Toolpath "Works" was copied but changed to a different ballnose.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
perspicax
in reply to: FrodoLoggins
I am also having this problem. What can be done to make it generate or get past 0.0%?
seth.madore
@perspicax without seeing your file, it's hard to say. Can you share it here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
perspicax
in reply to: seth.madore
This continues to happen with multiple different files. The original poster
shared their file so look at that one instead. I can't share my files.
To anybody experiencing the same problem here is the workaround solution:
you have to save and exit the part and re-open it. Fun bonus: fusion will
probably crash when saving and exiting a part that is still "generating" a
toolpath at 0%, so save your other open files as well before trying to exit
the original part. When you re-open the part there will be an error for the
toolpath. Simply regenerate and voila -- it works like it was supposed in
the first place.
