nweisz
484 Views, 3 Replies
In the Fanuc post, we need to preload first tool at the beginning of program prior to M6 (tool change command)
The generic Fanuc post preloads the first tool after the last tool is loaded in the program.
We would rather need it on a separate line before the tool change command at the beginning. This is the current output at the beginning of the program:
O3030 (TOP)
G90 G94 G17 G49 G40 G80
G20
G28 G91 Z0.
G90
(50MM FACE MILL)
T1 M06
T2
S3500 M03
G54
M08
G00 X5.4943 Y1.1
G43 Z0.6 H01
G00 Z0.2
G01 Z0.1 F50.
How can we modify the post to get this result?
O3030 (TOP)
G20
G28 G91 Z0.
G90
(50MM FACE MILL)
T1
M06
T2
S3500 M03
G54
M08
G00 X5.4943 Y1.1
G43 Z0.6 H01
G00 Z0.2
G01 Z0.1 F50.
Labels (1)
Arun.rs
in reply to: nweisz
Hi @nweisz
Thanks for raising your concern via Forum.
Open 'fanuc.cps' file in a 'Visual Studio Code' or 'Notepad++' to do the required modifications.
1. Go to line number 1469
Change from this :
writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
To This:
writeBlock("T" + toolFormat.format(tool.number));
writeBlock(mFormat.format(6));
Regards
Arun.RS
Technical Consultant - Post Processor
nweisz
in reply to: Arun.rs
Thank you. This is what we needed.
Arun.rs
in reply to: nweisz
HI @nweisz
About your query about the preload, you can simply untick the option in Post Properties,
Hope this helps !
Regards
Arun.RS
