mattdlr89
in reply to: db_kt
I was about to add this. Yes it is IPS as rest machining preview feature. The toolpath gets stuck because you do not have the IPS generated on the previous toolpath(s) and you are trying to do a rest machining operation.
You can get the toolpath to generate by either waiting for all the IPS to catch up or if IPS has got stuck on a previous operation you need to go and force regenerate that one so that IPS can generate for all the toolpaths and thus the toolpath is generated.
The 100% toolpath completion when you hover over it is very misleading - I think it means it has done 100% of the pre-processing but it is waiting for the IPS stock model to calculate the rest machining etc.
Personally I'd recommend not using IPS as rest machining for now.
