jeff.walters
in reply to: tmodcustoms
From what you said what you’re wanting to do is 2D pocketing. Trying to do it from your sketch will be next to imposable. What I would recommend is to create a “plate” and then create some extrudes to pocket out. You won’t have to do them all I would do the first two rows and then use pattern to do the rest.
Jeff Walters
Senior Support Engineer, CAM
