daniel_lyall
in reply to: fritter63
it would be easier to do it in two ops if you get a tapper fluted ball nose, you don't have to over run with them, for the angled bit do a project on to it off the outline and leave the drawing turned on then you select the drawing as your cut profile and it will cut it to the angle, It's a not that known trick fusion can do or (drawn tool paths). if not sure post your model and I will show you. the step-over is a bit different depending on the size of the cutter and angle at flute tip
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
