- Mute
- Permalink
- Report
Thanks Seth,
This work for all intent and practices. Creating a alternate WCS in SolidWorks I typically create point to attach the WCS to and then define orientation which seems to be much the same way that Joint Origin works.
It would be nice to be able to create a point from an existing point to a new plane. I realize there are alternate ways of doing this with in the create point functions in Fusion. Which tool to use of course is dependent on your geometry and your intent. It would be nice additional tool in Fusion to be able to just transpose a point to a plane....less clicks.
As mentioned all in all this works albeit different. The intent and usage is what I am after and you solved this one for me and others. Cheers! On to the next hurdle.
Gcode In Motion
SolidWorks 2021
HSMWorks 2022
Fusion360 - Manufacturing Extensions
Fusion
