nicclas.oscarsson
528 Views, 5 Replies
4th axis Machining
Hello!
I am kinda stuck at the moment, we just got a new machine. It’s a dmg mori dmf without 5th axis. So this machine only have 3axis and a Baxis in the spindlehead.
Problem is that when I tilt the b axis to machine far end side of part (B-90) it tries to go straight through part.
1. Tool change
2. tilt using cycle 19
3. Goes to start position xyz
4. Drill op
I could probably edit and have the Z axis movement first and XY after. But is this the right way to go? That would only work for the B90/B-90 I guess.
is this post related or can this be fixed in the manufacturing tab? My guess would be the post. But can’t figure how exactly.
Our post is the heidenhain generic with some small changes.
//Nicclas
Labels (2)
