in reply to: jonathanBUCVS
Some people altered X axis range in post to use up whatever stroke machine has below center line and by doing so avoid use of polar mode.
You have to be careful with that because once you use up Y axis stroke, only other option is polar mode and that uses X0 as center of C axis rotation, so if that value is modified in post, I would expect things to not work as intended with resulting code.
My take on it is, .... just learn how things work and use right methods to accomplish desired result ,..... "force" one thing or another by design and not by chance.
