in reply to: andypugh
@andypugh wrote:
Thanks, I don't know how you localised that as the problem, but it does look like the X-axis was the culprit. I am pretty sure that I had defined the X axis, but it looks like I "lost" it at some point.
It would have been nice if the log could have given a bit more of a clue to go on. It might have saved me a few hours of head-scratching and post-processor editing and mangling, and saved you however long it took you to spot the issue.
Again, thanks.
In your setup, each axis of triad needs to point to positive side of same axis in machine. When you select how to define orientation of axis, you also have to select face, edge, sketch line or plane to complete the process.
