- Mute
- Permalink
- Report
I have been running a modified LinuxCNC PP for a while, with the A-axis enabled.
I can't recall if I have ever used it, though.
I am trying to machine a hex on the end of a part using A-axis rotations. I have defined a tool orientation for each operation, and it all works fine in the simulation.
When I try to Post, however, I get no G-code, and the log is not helpful:
Information: Configuration: LinuxCNC_Milling
Information: Vendor: LinuxCNC
Information: Posting intermediate data to '/Users/andypugh/Fusion 360 CAM/nc/D14Cam.ngc'
Error: Failed to post process. See below for details.
Start time: Sat May 8 23:37:51 2021
Post processor engine: 4.5754.0
Configuration path: /Users/andypugh/Autodesk/Fusion 360 CAM/Posts/LinuxCNC_Milling.cps
Include paths: /Users/andypugh/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Sat May 8 23:37:37 2021
Output path: /Users/andypugh/Fusion 360 CAM/nc/D14Cam.ngc
Checksum of intermediate NC data: 6f7199aff633d0c5b16b5b723e07b872
Checksum of configuration: 6c965568a8c8293ac276eb779ab7ebcd
Vendor url: http://www.linuxcnc.org
Legal: Copyright (C) 2012-2021 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.10148
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Sat May 8 23:37:51 2021
Post processing failed.
I think that I have tracked the problem down to this line in the post, by adding some "warning" commands before and after.
function getWorkPlaneMachineABC(workPlane) {
var W = workPlane; // map to global frame
warning("Before");
var abc = machineConfiguration.getABC(W);
warning("After");
if (closestABC) {
Gives this output:
Warning: Before
Stop time: Sat May 8 23:48:20 2021
So it seems that the PP is giving up during the "machineConfiguration.GetABC(W)". But that does not appear to be code in the .cps file.
I have tried starting from scratch with the latest LinuxCNC generic post, and the EMC2 one too (after following the general instructions to add an A-axis)
It looks like the issue might be with my machine configuration. But I am not clear if that means the config in the post or the kinematics tree in the GUI.
I am working on a Mac, so most of the PP screenshots that I have found are no help, my PP dialog box looks utterly different, and I see no option to define the A-axis axis there.
Fusion
