05-05-2021
07:51 PM
- Mute
- Permalink
- Report
05-05-2021
07:51 PM
@jonathanBUCVS wrote:I recently noticed the Action command, specifically the useXZCMode and usePolarMode. These both seem to have the same output (XZC coordinates). Is there a code module that could be added for useXYZMode to force a Y axis move instead of a C axis rotation?
Sometimes the code will post with XYZ and sometimes its XZC, and I am not sure what the deciding factor is.
Specific post I am using is Doosan mill-turn fanuc.
There is no such command as useXYZMode, if machine has Y axis, you are using XYZ mode by default in any work with radial tool orientation and G19 plane (YZ)
"useXCZmode" can only be done in G17 plane (XY), tool set in axial direction and working above spindle center line.
Check out this thread:
Fusion
