- Mute
- Permalink
- Report
We're trying to utilize F360 to engrave a pattern wrapped 360 degrees on a cylinder around a 4th axis with G02/03 output. I'm having trouble getting the post processor to output G02/03 and think it may be the tool path.
- Mute
- Permalink
- Report
On wrapping a pattern on a cylinder the machine will effectively(once Z has positioned for depth) be only moving your rotary axis and one liner axis(on my config A and X). You can only have G02/G03 moves on planes across linear axis, not rotary axis, except for lead in/out moves.
A wrapped tool path around a rotary axis will have to do a multitude of small point to point moves, the distance between these points will be effected by the path/smoothing tolerances and therefore increase your program size.
- Mute
- Permalink
- Report
Thanks for the quick response-
Just clarify, Fusion will restrict to linearization for rotary axis? Asking because I'm able to go the manual route and run this on a rotary axis:
G07.1C.1875
(CYLINDRICAL MAPPING)
G01X.385F1.0
(SLOT CAM)
G03C-22.398Z-.4988U-.01R.3987F3.0
G03C-1.256Z-.7228U-.01R.3987
G03C-.2124Z-.7249R.005
G03C5.362Z-.7263R.1275
G03C39.648Z-.6599R.1275
G03C39.832Z-.6575R.005
G03C38.3Z-.6525R.005
G03C36.952Z-.6551R.005
G02C33.398Z-.6724R.1175
- Mute
- Permalink
- Report
Any chance you could attach a file to show what kind of wrapping project you are working on?
- Mute
- Permalink
- Report
Hello @shopping3RT5G
Effectively when Fusion is passing the toolpath to the post, we only have the wrapped toolpath.
So it's linearized without G2/G3.
We don't have actually the ability to retrieve the un-wrapped toolpath.
We have no post support function like G107 or TRACYL.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
- Mute
- Permalink
- Report
Hi
Is there a possibility for TRACYL in the Post Processors? SIEMENS 840D with FUSION360
- Mute
- Permalink
- Report
Hi @f_feroglu
No, the behavior is still the same.
When the toolpath is generated by Fusion, it is created from the solid, or from an edge that is wrapped on the cylinder like that one :
But to use tracyl or any similar function like G107, you must have the unwrapped curve, i.e., that one:
The flattened curve is currently not created by Fusion, so it cannot be passed to the post engine.
Regards.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
it doesn't really depend on the exact shape. It's a general limitation of the system.
That doesn't mean, that it's not doable, but you'd need someone who really know's what they're doing,
it will be complicated to do (will be hard to find someone who would do something like this remotely for free, I'd say),
and one'd be working "against" the system or rather against how things work in the system.
But then... If you have a look at how subroutines are implemented in the posts, things are not really soo much more elegant there, imho...
Did not really spend much time on thinking this through, but roughly sketched out one could try the following:
- check operation parameters for 4x wrapped op. Probably
'operation:is2DStrategy' , 'operation:isRotaryStrategy' (should both probably have a value of 1) and 'operation:isMultiAxisStrategy' (this one probably 0).
- turn off movement output in onSection (start of op) and record moves / params.
- after the section is done (e.g. in onSectionEnd), unwrap all recorded coordinates.
- do a 2D arc fit (there are quite a few resources on that if you really look for it).
- output all moves, including G02/03. You might do the output manually, or probably you could also call the respective onLinear, etc. functions yourself and pass the recorded params. You'd have to test that.
I'm not really interested in implementing the above, and I won't recommend it, but if you found someone... From the top of my head, that could be a way to go about solving your problem.
Good luck
Martin
Fusion
