- Mute
- Permalink
- Report
The method I just found that will update the manufacturing model version to the same as the design model is:
1. Go to manufacturing workspace
2. Expand manufacturing model folder to check version
3. Go back to design workspace
4. Edit the sketch
5. Finish edit sketch without making changes
6. Go back to manufacturing workspace
7. Expand manufacturing model folder and check version number, it should have updated.
I know it sounds stupid and it definitely sounds like an unintentional "feature" (which finding it was also unintentional) but it has worked for me the last three times I have had issues updating my manufacturing model (albeit, this was on only one file so far and my file only has one sketch, not sure how it will work with a design that has multiple sketches). The only issue I have seen is that sometimes it breaks projected sketch geometry in your manufacturing model so you have to re-link them and also double check your tool paths are in the right location because one time one of the tool paths turned 90 degrees but the other two didn't rotate so I just had to reselect the profiles the rotated ones were cutting.
Fusion
