458 Views, 2 Replies
Cutting Height Mach3 Plasma
Hi, I am unable to find cutting height in the Mach3 Plasma Post Process Properties.
I'm using the latest Mach3cps file.
I'm able to set Pierce delay and heights but "Cutting Height" is not shown as an option.
Please help.
Thank you.
Labels (2)
daniel_lyall
Have a search through the forum there are a couple of edited posts out there.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
boopathi.sivakumar
Hi @Anonymous
You can set the cutting height in the heights tab as mentioned below
But the problem will be your pierce height will get offset by this value.
to avoid that, say if your pierce height is 3.8 and cutting height is 1.5 then in fusion you need to set the height 1.5 in the heights tab and for pierce height you need to enter 2.3 (3.8 - 1.5) in the post processor dialog.
I agree that there is still some space to improvement in the post processor as well i will log a ticket and will find a more better solution. But this works as well
Boopathi Sivakumar
Senior Technology Consultant
