engineguy
in reply to: salesSS33M
@salesSS33M
Can`t use a 160mm diameter tool to cut a 27mm diameter arc ???
Best way would be to use a 15mm slot cutter and plunge straight down the hole which you will need to pocket out rather than your Bore operation which leaves a pillar in the middle, not ideal :slightly_smiling_face:
Easier if you take a look at the attached file, rather than me trying to go through it all in text, a bit rough but hopefully you can fine tune it to suit, just an example as a "pointer" for you, take particular note of the settings in the "Link" tab, these move the plunge around !!
Hope it helps a little.
