fredsi
in reply to: LibertyMachine
gearsoup,
Just tried negative values in Tangential Extension on PC at work (Win7 64b) and it took it with no problem.
RE: persistent values. Presumably you've gone into the compare and edit tables and RMB to set defaults, set all defaults, edit formulas and the like? This has helped me quite a bit with standardizing ops and getting rid of annoying values (for me) like vertical radii. Once again, apologies if this is old news.
Fred
