raceman17
144 Views, 1 Reply
Haas Tooling Library Incorrect
I downloaded the Haas Tooling Library from the website.  It appears that all the Alum-Mill Endmill feeds and speeds are not correct at all.  It shows some RPM values up in the 60000 Range.  Is there anyway that these items can be fixed in the library?
seth.madore
in reply to: raceman17
As I understand it, the creators of each library are responsible for the data that's contained, not Autodesk. Which tool and Cutting Data setting was up in the 60k range?
It's actually quite conceivable that IS the correct rpm for that tool.
My advice? Copy the tools over to your own library, change the speeds to suit your needs and carry on
Seth Madore
