- Mute
- Permalink
- Report
When I facing my stock it leaves a thin edge ( because the object is smaller than the stock?)
The milling path is strange, I need to move it sideways but how?
I really like to face the whole stock area.
/Håkan
- Mute
- Permalink
- Report
It looks like you selected something for your stock contours in the operation. If you lear that and run the operations how does it look?
Senior Support Engineer, CAM
- Mute
- Permalink
- Report
Yes I select the contour of the object, so the object is clean but I like to face the whole stock.
Is that possible?
/Håkan
- Mute
- Permalink
- Report
just clear the object selection(red X) and you should be all set
- Mute
- Permalink
- Report
Sorry, I'm still learning can't understand "clear the object selection(red X)"
Edit:
OK Now I see, thanks!
/Regards
Håkan
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Faced the same issue... which was solved by the same answer. Thanks a lot Jeff.
Fusion
