500 Views, 2 Replies
Attach CID 215 (flange) as a connector
Hi all,
I've posted this in another forum and am hoping someone can help.
       I'm trying to use CID 215 (from the Z-master folder) as a connector but the only parts available in the connector drop-down menu are flanges from services that don't use this flange. This flange has attributes that allow the user full control of O/D, PCD, I/D, Hole diameter, amount of holes and thickness. I have seen this flange in the Z-master folder but it can't be applied with the attacher function, is there a way to get it from that folder into the connector drop-down menu?
TIA.
