12-15-2015
12:02 PM
- Mute
- Permalink
- Report
12-15-2015
12:02 PM
The above is correct. You need one license per one person. So if you have 3 concurrent users, you need three seats. If you don't have to work concurrently, then you can all share one seat of network, but only one person at a time can use any of the suite software.
Travis Nave
HOT: Named User FAQ | 2025 Download Links | Invalid Serial Number | LiteHTML.DLL error | Reset Autodesk 2020-25 Licensing
Disk Space | Quickstart Guide for LMTOOLS | Edit setup.ini for 1603 Installation Failure | 1603 Error installing /w Updates | Disable Optimus
Understanding Failures in the Installation .log File | Server Status from Client | Autodesk 2024 System Requirements Fix | Reuse USB Stick
⤽ If my post was helpful, please give Likes and/or mark the Accept as Solution button(s) below. Thank you! ⤵
