pan.davarias
857 Views, 11 Replies
Surfacebook, Windows 10 and Autodesk products
Hello
I have a couple of questions about the surfacebook and windows 10 and their compatability with AutoCAD, Revit and Navis.
While everything I have read tells me, for a mobile solution, the top end Surfacebook should run the above reasonably well, my question is does anyone know if Microsoft support the downgradeto Windows 7 to allow these products to run as they should?
Windows 10, for now, is not supported by Autodesk. Any idea when this may happen?
Pan
in reply to: pan.davarias
The issue is going to be drivers and if the Win 7 will work with the Surfacebook.  I know people of have downgraded a Win 8 machine to Win 7 and that didn't go as planned (lots of driver issues).  It appears there are several people over at the other forum that are running Win 10 with no problems.
I am also looking at getting a Surfacebook in the next week or so.  I am going to run it in Windows 10 though.
pan.davarias
Hi Ken. I have got the surface book now running win10, fab,revit and navis.
I am not overly pleased with the performance with this software presently.
I will be keen to know your views when you get yours
Which one did you get (HDD and RAM)?  I have been looking at the 512 gb/16 GB ram.  It also has the NVIDIA graphics card (seems like the cheaper ones don't have this though).
pan.davarias
Hi Ken
i got the top end one
512GB, 16GB RAM with the NVIDEA card
Oh, that is the one I was interested in getting.  Hmmm, I may need to go elsewhere then.
pan.davarias
From what I am hearing, it is a win 10 thing. Autodesk has not yet come out and supported all the software for windows 10 so service packs. hopefully will fix the issue.
All the prior research I carried out showed this would be more than adequate. The service pro 3 runs all of the software noted below easily so the surface book SHOULD do so without problem
I hope it is this and not that I have got a dud machine....
That makes sense. I was thinking it shold be fine as well.  AutoCAD is also listed in the comparison chart for the different MS Surface tablets.
Thank you.
Is it crashing or just slow?  I can handle slow until they make it work in Win 10.
Looks like I am not going to be needing that new laptop now.  Bummed.  Keep us posted if you get the performance up though.
Bought a surface myself...sold it and got an Asus laptop.
Surface is not ready for Autocad use....
pan.davarias
I have my surface book running with Autocad abd Fab now. Had to mess about with the screen resolution a bit to see all of the icons on mu toolbars. A few minor issues still but i much moe optimistic now
