10-02-2015
07:24 AM
- Mute
- Permalink
- Report
10-02-2015
07:24 AM
I can re-create the issue using Autodesk content.
To be more specific I am using the "Cut-In" option for the fitting and then using the "Fixer" command line option. In the Fix and Rotate dialog I am checking the "Fall in degrees" box and then inputting -45 to roll the fitting. Once fitting is placed in the drawing the couplings come in with the halo.
I have narrowed it down to couplings rotated at 45 degrees. Couplings rotated at any other angle do not produce the halo.
