238 Views, 0 Replies
Spooling BUG Quantity in BOM 2016
Has anyone run across a bug with the spool report in 2016?  I have a report that if I run on a selected pipe, the quantities are correct.  If I run the spool command that pulls the same report anything that has a quantity over 1, the quantity on the BOM shows more fittings than needed.  Example:  2 - tees are drawn, BOM shows 3 tees needed.  This happens every time there are 2 of anything drawn.  Same for 3 of something, the BOM shows 5 needed.  Please see the attached image for an example.  The top BOM is the automatically generated spool, the bottom is the manual addreport in the same drawing.
