08-07-2015
07:14 AM
- Mute
- Permalink
- Report
08-07-2015
07:14 AM
Honestly it sounds like you might benefit from some basic training. Adding fittings is a pretty basic part of the program.
Go to your Service Database and path to the fittings you want to add to your pallet. See Image
Also, use the command Folders to view the .itms available in your library.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
