401 Views, 1 Reply
Adding fittings to the duct pallet or duct menu.
Hi, could you please helpme, most of my work is duct design, and thinngs related with ventilation... ok, i have a problem, i would like to increase my duct pallet options adding other kind of elbows or Tee, or duct branches.. i was searching the libraries and i found that there are a lot of duct fitting that i cant find on my actual duct pallet/menu, those files are .itm extention, and i really dont know what to do with that... could you explainme how to add those fittings or to the duct pallet. do I have to download every fitting that i would like to use?
I have made a list with the command makepad + number, but it's really annoying doing that for every branch o coupling or derivation that i need... so, help please?
davidronson
Honestly it sounds like you might benefit from some basic training. Adding fittings is a pretty basic part of the program.
Go to your Service Database and path to the fittings you want to add to your pallet. See Image
Also, use the command Folders to view the .itms available in your library.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
