- Mute
- Permalink
- Report
No Hub Couplings in 2016
My No Hub couplings in 2016 have get a weird halo in the connector when they are rotated. See attached image.
Anybody else seeing this?
- Mute
- Permalink
- Report
I am using 2016 as well and just tried to see if I could get the same halo you are talking about by rotating 45 degrees up. I am not seeing the halo, what material are you using?
- Mute
- Permalink
- Report
Cast Iron. Material hasn’t changed. None of the previous versions did this.
I am placing attacher arrow at the end of a pipe. Using ALT and rotating attacher arrow 45 degrees and then drawing a comby or just drawing a coupling and the halos appear.
It also happens if I do a “Takeoff as cutin” and roll the comby.
- Mute
- Permalink
- Report
Tried a couple of our configurations as well as the 2016 Autodesk config and do not see this.
Tried 2016 both with and without SP1.
Give the Autodesk's default content a try. That should isolate if it's an issue with the software/install or your content.
As much as I can, I try to recrease my issues w/Autodesk's content when sending them to them to eliminate the whole "it's your database" part of the equasion.
- Mute
- Permalink
- Report
I can re-create the issue using Autodesk content.
To be more specific I am using the "Cut-In" option for the fitting and then using the "Fixer" command line option. In the Fix and Rotate dialog I am checking the "Fall in degrees" box and then inputting -45 to roll the fitting. Once fitting is placed in the drawing the couplings come in with the halo.
I have narrowed it down to couplings rotated at 45 degrees. Couplings rotated at any other angle do not produce the halo.
- Mute
- Permalink
- Report
i have been seeing the same thing lately, but i dont think it was no hub,
edit, here it is, it is non-pitched sch40 cs. the weld and the flange are showing it.
my pd size is 0
