- Mute
- Permalink
- Report
When placing a copper tube, say from the autodesk library (Pipe-B88-CU-L(PE)), then stretching the pipe, doing a fill, anything I will get the waringing "Dimension B is Invalid (0.4375)". The warning has the heading Pattern: - 1/4 and I have to click ok through the entire product list. This can happen with only placing pipe on its own and trying to stretch it. I have had this problem with earlier versions where I'd turn off the insulation. Not the case in this instance. All insualation and insulation specs are off and not set. I am using CADmep 2016 SP-1 and AutoCAD MEP 2016 with the hotfix's installed. I've tried a new drawing and still get the same occurance.
Is anyone else having this problem? If so, is there a fix other than getting rid of product lists and calc the same pipe size?
- Mute
- Permalink
- Report
Yeah, it happens in a new blank drawing with insulation off... I've also noticed that it only does it for the sizes 1" and below.
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
When investigating your issue I discovered I had the same issue. I excluded every fitting in the service until the error stopped. I found a flange that I made with an invalid dimension that was causing the error. The invalid dimension wasn't an issue until it was used in 2016 software.
- Mute
- Permalink
- Report
@MOatman wrote:When investigating your issue I discovered I had the same issue. I excluded every fitting in the service until the error stopped. I found a flange that I made with an invalid dimension that was causing the error. The invalid dimension wasn't an issue until it was used in 2016 software.
Awesome! Don't have 16 here to work with.
- Mute
- Permalink
- Report
