- Mute
- Permalink
- Report
Spool Drawings problem - Added Pipework showing up in ALL spool drawings
Hi guys. The issue my company is having is when after we have defined the spools and created spool drawings and making revisions. If we add any additional pipework to any of the defined Spools in the model after the drawings have already been created.. say a Rev 2, then the new pipework shows up in ALL of the Spool Drawings regardless of service... which can be quite a number. Sure this new pipework can be turned off using "hide in Viewport" or layers but it is really annoying to do it manually for every drawing and some of the fittings might be small and overlooked. Also we could redefine the spool and run a new drawing but we lose the positioning on all of the annotation for that drawing, which is again more time wasted. I use the CadMep match properties button as well as the Autocad "Matchprop" command to add in the new pipework to the spool. Is there a way that we can prevent these new pipes and fittings from showing up in all the Pipe spool drawings except for the one they are intended to be added to? Any help is appreciated. thanks
