454 Views, 3 Replies
Creating a custom Panel
I want to create a custom panel, however I do not have access to all of the 'buttons' which are shown on the CADmep toolbar which is loaded in using TBAR.
When typing 'cui' and browsing through all available commands, it appears that there are no CAD Fabrication commands at all.
Where are they?
If I have to re-create them all manually (which is a bit long winded) I do not know the commands for some of the buttons as when they are pressed the automativcally invoke a dialogue box and leave no history of the command to use
For example...
1: Pressing the 'Multi Service Layout Editor' button shows the Multiple Service layout dialogue box with no trace of the command used.
however...
2: Pressing the 'New Design Line' button shows that the command used is 'adddobj'
To sum up - basically where are all the 'buttons' stored so I can utilise them to make a more user friendly 'panel' to add to my home tab.
Or if they are a secret... What are the commands for all of the buttons on all of the CADmep toolbars?
I have browsed for some of the missing commands on this link however nothing was found..
http://help.autodesk.com/view/FABRICATION/2015/ENU/?guid=GUID-98C31D5D-5D77-45C5-BA76-48DAE7640A3C
Also loooking at the MultiSevrice line Autocad help section, it does not give the commands Edit MSL Command I need.
