davidronson
You can make additional fittings using the "makepat" command. There are many different patterns see the attached pdf.
In regards to the report, if you want your report to be in CAD use the "addreport" command, if you want to print it out in PDF form use the "report" command. There is a large list of print object to choose from, it will look scary at first. Sometimes the best thing to do is to open an existing report and analyze it. Look a every tab.
______________________________________________
Don't forget to "Accept As Solution" and "Give Kudos" when an acceptable solution has been given.
|| LinkedIn || LinkedIn Fabrication Group ||
