08-01-2024
12:32 PM
- Mute
- Permalink
- Report
08-01-2024
12:32 PM
Chris,
If you are unable to access the given profile. I would not recommend trying to remap your profile individually, while it can be done. The recommended workflow would be to remove the profile via the "profile setup dialog" and recreate it. Remapping profiles has a tendency to corrupt the profiles.map file within the Fabrication database - profiles folder. I opt to backup the profiles.map file each time I create a new profile because of this tendency. If you need to remap the profile I would backup the profiles.map file first.
