Neil_Markham
772 Views, 1 Reply
Text Size variations in different scale Viewports
I am currently working with a system and have created 2x Layouts.
In Layout #1 the Viewport scale is set and locked to 1:100.
In Layout #2 the Viewport scale is set and locked to 1:50.
How can I control the label text to display at the correct height (2.5mm) in both differently scaled layouts?
The AutoCAD Text Style is STANDARD (isocp.shx, Height = 250mm)
CADmep Main Database > Takeoff > CAD Settings > Annotation > Number Text, Size Text, Level Text, Offset Text & Alias Text > Text Style = STANDARD
The current result is that on Layout #1 the text is 2.5mm high and on Layout #2 the text is 5mm high)
I would normally control text heights using an Annotative Text style but this does not work in CADmep (in my experience)
Neil :slightly_smiling_face:
